Cooling fan runs when engine is off
106,000 MILES • 3.3L • 6 CYL • AUTOMATIC
NBLANKE688
Engine was off three to four hours, fan did not stop, ran battery down. I replaced thermostat but that did not work. Is fan relay the most likely problem?
Oct 15, 2017 at 1:33 AM
HARRY P
  • 2,292 POSTS
My best guess would be a bad cooling fan relay (the thing that turns the fan on and off). If it got stuck, it would just keep running until the battery was drained. It appears to be a common problem. It is located apparently under the air cleaner box. Once that box is out, it is a simple job really. I will include a picture to aid you.
Here is another thread for the same problem. It is a little more descriptive.
https://www.2carpros.com/questions/2002-chrysler-town-and-country-t-c-33liter
Oct 15, 2017 at 1:56 AM
NBLANKE688
Thank you very much! Will follow your thread, and thanks for it, too!
Noel Blankenship
Kent, Ohio
Oct 15, 2017 at 2:15 AM
