Cooling fan running slow
2013 TOYOTA COROLLA
120,000 MILES • 1.8L • 4 CYL • 2WD • AUTOMATIC
SRDRAMOS
My cooling fan is running slow. It is fast enough to cool down the motor but is not enough to cool down the AC radiator. I connected the fan directly to 12 volts and work fine. Checked the relay also and is working.
Any idea?
Jul 2, 2018 at 3:30 AM
  • 110,244 POSTS
When you connected it direct to the battery, did you provide both power from the battery plus a ground? Often times, a weak ground can cause resistance and lower the power supply.
Let me know if that is what you did. If it is, provide a new ground for the fan. If it is not, check the wiring for resistance issues, bad connections.
Here is a link that discusses how to check wiring:
Jul 2, 2018 at 12:00 PM
