The cooling fan motor was making a lot of noise, I replaced it with the new fan. It seemed to work for a few days, replaced the battery. A few days later, the cooling fan stop response to the normal fan level, I replaced the sensor, still, it is not working as it should. Turn on the A/C the cooling fan is working, unplug the sensor wire the cooling fan is working fine. I plan to replace the thermostat and I plan to unplug the battery to reset the PCM.
Jun 14, 2019 at 6:13 PM
