cooling fan quit
160,000 MILES • 6 CYL • 4WD • AUTOMATIC
MNMAN2
Fan basically shorted out and caught fire a little! Unplugged it and no problem, plugged it back in and it immediately began to smoke. Obviously I need to replace it?
But my question is, it's super cold out, northern MN in the winter -24 degrees this morning, (LOL) It's also New Years Day. I drove it home last night (fifteen minutes) and it stayed cool (working gauge sub 190 degrees).
So is it safe to drive in these cold temperatures as long as I watch the heat gauge? Just for a couple days until I get the part?
Dec 31, 2018 at 9:43 PM
Good morning,
Yes, you need to be sure that you watch it at idle situations as that is when it is needed the most.
https://www.2carpros.com/articles/replace-electric-fan-motor
If you use the defroster, the AC will kick in and the fan should come on. without the fan, it may make a difference in cleaning off the inside of your windshield.
Dec 31, 2018 at 9:57 PM
