Cooling fan not working?
2009 FORD EDGE
110,000 MILES • 3.5L • V6 • FWD • AUTOMATIC
ANDREW CARBERRY
Went to jump a friend a few months ago. Our vehicle overheated. Since then it overheats randomly. We figured out the cooling fan is not turning on. We pulled it out and tested it. Worked fine. Still replaced to be sure and still is not working. No clue where to go next. Please help us! Only car we have for our family.
Aug 21, 2017 at 5:45 PM
  • CAR REPAIR CONTRIBUTOR
More than likely you have a head gasket issue. We need to start with testing this to find out for sure if it is failed. Here is a guide that will help with this:
More than likely you will need to get the engine hot and then perform this test as they may not show up as failed if they are cold.
If this is okay then we need to check the following items on these guides that covers overheat issues:
https://www.2carpros.com/articles/symptoms-of-an-overheating-engine
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Let's run through this material and let us know what you find. Thanks
Jan 27, 2021 at 12:04 PM
