cooling fan operation
100,000 MILES • FWD • AUTOMATIC
PHILIL
The other day i was on some Mitsubishi lancer forum researching a problem.i had. (cooling fan control.module) but i read a post from a Mitsubishi tech tell someone with same prob that the cooling fan will only work if a/c is on. Is this correct? I don't see why that would have anything to do with the fan operation. Please explain if possible. Thank you in advance.
Aug 30, 2016 at 6:36 AM
WRENCHTECH
  • 20,760 POSTS
It should run all the time when the AC is on and regulated by temp for cooling. If it comes on when the AC is turned on, that tells you the control circuit is fine.
Dec 29, 2018 at 2:52 AM
PHILIL
that makes sense...thank you for your timely & informative response.
  • 55,694 POSTS
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
