Cooling fan not functioning, wiring diagram for the cooling system needed?
234,356 MILES • V6 • 2WD • AUTOMATIC
BLESSING EWOBOR
  • 753 POSTS
The cooling fan of the engine is not functioning. Could I have the wire diagram for the cooling system?
Feb 27, 2025 at 11:28 AM
  • 110,248 POSTS
Before tearing into the circuit, run power directly to the fans to make sure they are functional. If they are, keep in mind there are three relays. I just took a look and from what I'm seeing, fan relay 1, located in under the hood in the engine compartment, must work for the other two to get power. I would start there.
I attached the wiring schematic below for you. I had to cut the pic in two to make it readable. I did overlap the two so you can follow from one to the next.
I hope this helps. Let me know if you have questions.
joe
Feb 28, 2025 at 12:39 PM
BLESSING EWOBOR
  • 753 POSTS
Thank you very much.
Mar 1, 2025 at 12:48 AM
  • 55,746 POSTS
JACOBANDNICKOLAS is one of our best, let us know if you need anything else.
Mar 3, 2025 at 2:27 AM
BLESSING EWOBOR
  • 753 POSTS
Mar 4, 2025 at 3:04 AM
