COOLING FANs Not working
85,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
MAVERICK
I have changed the temperature sensor three times, the thermostat twice, and now i have completely replaced the cooling fan assembly and i still cannot get the cooling fans to come on. Not with the a/c, not with normal operation. Unless i wire it up to the battery the fans will not work. Does anyone know if the blower motor resistor would have anything to do (even though all speeds work fine and a/c blows cold and heat blows hot on all speeds) i m seriously at my wits end with this car. It does not have a relay and the fuse i changed twice also.
Oct 3, 2016 at 7:55 AM
HMAC300
  • 48,601 POSTS
check the light blue wire at fan motor see if power comes on when a/c is turned on. if not then go to #14 on PCM and see if it is there if not it may be one other sensor like pressure or evaporator discharge sensor also check ground at right front fender.
Oct 3, 2016 at 8:19 AM
MAVERICK
Okay, what am I looking for on the PCm? Power when the AC is on?
Oct 4, 2016 at 12:40 AM
HMAC300
  • 48,601 POSTS
yes there may be several light blue wires so go to #14 on connector it is marked small but marked.
Oct 4, 2016 at 2:24 AM
