Cooling fan is not working the fan motor is good
98,000 MILES • 3.3L • V6 • AUTOMATIC
JOSEPH UGWUNEKE
The cooling fans are not working. There is power on supply to the fan controller, but the module does not run the fans. What voltage is expected from the small wire that comes with the power cable?
Jun 26, 2022 at 3:48 PM
  • 55,649 POSTS
It sounds like the controller is bad, but here are the cooling fan wiring diagrams so you can see how the system works. The signal comes from the engine ECU. This guide can help you check the wiring connections to help find the problem:
Jun 27, 2022 at 4:59 AM
