Cooling fan does not come on
110,000 MILES • 2.9L • V6 • 2WD • AUTOMATIC
URSULOROBLES
  • 47 POSTS
A/C does not cool.
Sep 30, 2019 at 8:53 AM
  • 110,248 POSTS
Welcome to 2CarPros.
This could be the result of a few things. First, are you certain that the AC system is fully charged? If it fails to actuate the compressor, the fan won't turn on. Here are a couple links. The first one discusses common issues with AC not working. The second explains how to charge the system.
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
Let me know if that helps or if you have other questions.
Oct 1, 2019 at 11:27 AM
URSULOROBLES
  • 47 POSTS
With engine running, the low side is high and high side is low, when A/C is on, the compressor clicks on and low pressure goes down to 100 , but the fan does not come on. therefore the A/C compressor disengages and vehicle gets hot.
Oct 4, 2019 at 11:41 AM
  • 110,248 POSTS
Welcome back:
If the low side goes down to 100, that is extremely high. The idea that the low goes high and the high goes low, I suspect the compressor is bad. If the low side goes down to 100 where does it start?
Oct 4, 2019 at 2:24 PM
URSULOROBLES
  • 47 POSTS
the A/C low side is over 100, compressor clicks on with no cooling fan, and low side pressure goes down to 100 and compressor shuts off.
Oct 6, 2019 at 5:25 AM
  • 110,248 POSTS
Welcome back:
I suspect either the system is either over charged (high pressure switch turning it off) or the compressor is bad. Even under extreme conditions, for example at 110°F low pressure should be under 60. Could you have over charged it?
Oct 6, 2019 at 12:56 PM
