Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Cadillac
SRX
Engine Cooling
Cooling Fan
Not Working
Cooling fan not working
2010 CADILLAC SRX
150,000 MILES • 2.8L • 6 CYL • 4WD • AUTOMATIC
JEFF GAUTSCHE
MEMBER
1 POST
Test fan and power source without dealer computer?
Feb 26, 2020 at 12:30 AM
Experienced Mechanic
Good morning,
You can remove the connector for the coolant sensor with the key on. The cooling fan should come on.
I will attach a wiring diagram and a flow chart for you to view.
Images (Click to enlarge)
Feb 26, 2020 at 3:10 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
