The cooling fans only turn on when the temperature sensor is unplugged?
194,000 MILES • 5.3L • V8 • 4WD • AUTOMATIC
SLIM71US61
I replaced the radiator, all hoses, and the overflow kit, temperature sensor and plug relays. I'm at my wits in?
Aug 4, 2023 at 11:14 AM
  • 110,251 POSTS
First, make sure there is power to fuses (three of them) in the under-hood cooling fan relay box.
Next, you indicated the replacement of the relays. For them to actuate and turn a fan motor on, the PCM needs to provide a ground path to complete the primary side of the relay.
I attached the wiring schematic below. See if the wires I indicated have continuity to ground when the fans should be on.
Also, take a look through this link for a better description of the relay operation:
joe
Aug 4, 2023 at 3:34 PM
