New cooling fan not working
180 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
JOHNOFBHAM
Installed new cooling fan, ECT sensor, relay and fuse.
If the thermostat is stuck closed will this not allow the fan to operate?
Jun 24, 2019 at 3:21 AM
Good afternoon,
Did you check for power to the relay? You need to test for power to the wires I highlighted in the diagram.
https://www.2carpros.com/articles/how-an-electric-cooling-fan-works
No, if the thermostat was stuck closed, it would heat up real fast and will turn on the fan.
Does it come on with the AC?
Jun 24, 2019 at 6:03 AM
JOHNOFBHAM
Thank you. I should be able to troubleshoot that tomorrow and will get back with the results.
Jun 24, 2019 at 9:51 AM
Sounds good.
You are welcome.
Always glad to help.
Jun 24, 2019 at 11:35 AM
