Cooling fan, I purchased coolant that is a different color, will adding it cause problems?
55,000 MILES • 1.4L • 2WD • AUTOMATIC
SNENNA2002
I went to shut off my car and I noticed that my fan was still running on my car. When I looked at the coolant, I did see that it was low. Now the coolant I got for it says it's compatible but it's a different color coolant. I just wanted to know is that going to cause me problems if I add it.
Aug 15, 2023 at 10:28 PM
  • 55,594 POSTS
Yes, you should be okay, but I would try to get the correct color because it may affect the warranty.
Please check out this video:
https://youtu.be/GSE9skKnOgY
Engine Cooling System: DEX-COOL Part# 12346290
Aug 16, 2023 at 5:42 AM
