Cooling fan
123,000 MILES • 3.5L • 6 CYL • 2WD • AUTOMATIC
DADDYA
  • 29 POSTS
I have installed a new AC compressor, temperature sensor, radiator and condenser checked the fuses and they are all good. A/C is fully charged and blowing cold air and the bottom fan comes on the top fan will not kick in until temperature gauge is normal half way.Engine is not running hot is this normal?
Sep 29, 2017 at 8:55 PM
STEVE W.
  • 15,421 POSTS
Sounds normal. One fan will turn on with the AC, the other is controlled by engine temperature, until it gets very warm, then they will both be on even if the AC is off.
Sep 30, 2017 at 6:03 AM
DADDYA
  • 29 POSTS
Thanks Steve W. I really appreciate it.
Sep 30, 2017 at 9:12 AM
STEVE W.
  • 15,421 POSTS
You are welcome. Thank you for using 2CarPros.com. Return any time with your automotive questions.
Sep 30, 2017 at 1:09 PM
