cooling fan
744,000 MILES
RACINGPATRICK
My cooling fan is not coming on, is it a relay? or is there a switch on dash to turn it on?........... it does not turn on even when temperature increases to 200 degrees. I was wondering if it could be thermostat or a relay?thank you.
Also where is the thermostat located?
thank you
May 14, 2013 at 1:09 AM
HMAC300
  • 48,601 POSTS
we have no listing inour manuals for this truck. the thermostat shold be inline of top rad hose. but what size truck is it? if there is a realy it should be in the electrical center underhood. fuse as well.
May 14, 2013 at 2:42 AM
