Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Highlander
Climate Control
Air Conditioner
Compressor
Clutch
A/C clutch not engaging properly?
2002 TOYOTA HIGHLANDER
197,000 MILES • 3.0L • V6 • 4WD • AUTOMATIC
DROPDROPS11
MEMBER
1 POST
a/c clutch won't engage until i jump the relay.
Sep 4, 2022 at 2:57 PM
Experienced Mechanic
Do you have enough refrigerant in the system? If the refrigerant is low the system will not come on.
Here is a video to help you add refrigerant to see if this is the problem:
https://youtu.be/uZrQCGwXfek
and
https://youtu.be/ON2dYcmXIAw
Let me know what you find.
Sep 5, 2022 at 10:59 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
