Cooling circuit diagram needed
3,000 MILES • AUTOMATIC
SER3NIK
  • 6 POSTS
Hello! Can anyone help me with a cooling circuit diagram for this type of car? There are some items that seem not to fit anywhere. :) I'm not sure how it's called. something with "exploded" diagram. Thanks in advance.
Vehicle listed above is a E300 hybrid.
Dec 3, 2021 at 4:22 PM
Unfortunately, the manual for this new of a vehicle is not detailed as the OEM has not published a lot of this detail to the aftermarket yet. So that means we are going to have to try and figure this out by getting some detail as to what you are looking at.
If you can post some pictures as to what you are looking at then we should be able to figure out what it is that we need to do.
Are you making a repair or replacing some parts? Or are you just looking at the engine compartment and wondering what some parts are as they appear to not fit correctly?
Do you have any issues with the vehicle?
I am attaching the one exploded view that they have so let me know if you can get some pictures or if this is what you are looking for.
Thanks
Dec 4, 2021 at 6:22 AM
SER3NIK
  • 6 POSTS
Hi, there! Thank you for your time. I'm trying to replace some items due to a little crush and i wanted to check the diagram so i can put everything in place. I'm having troubles finding the no 10 item, you know it's very expensive and no aftermarket yet. :) i'll keep you posted how it goes. Thanks again!
Dec 4, 2021 at 5:07 PM
Yeah. Unfortunately, it will be a little while before they get parts and more info out on these vehicles.
Let us know how you make out and if you need more info and we will get what we can. Thanks
Dec 4, 2021 at 10:26 PM
