Typically if you have low Freon and or clogged condenser.
You should first check the Freon level. If it is low it needs to be recharged.
Here is couple of helpful article of how to recharge your A/C system:
https://www.2carpros.com/articles/air-conditioner-how-to-add-freon
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
https://youtu.be/uZrQCGwXfek
If the Freon level is correct then second item could be a clogged or damaged condenser.
If the condenser is faulty then you won't have proper amount of air flowing through it to make the air cold out of the vent.
Jul 29, 2021 at 12:07 PM
