Coolent
50,000 MILES
AMBER16
I put antifreeze in my car coolent. As I poured it in I then realised the antifreeze is moldy. Just want to know if the car coolent will be ok with mold in it? :/
Aug 26, 2016 at 3:34 AM
CARADIODOC
  • 34,414 POSTS
I've never seen moldy antifreeze. What does it look like? I suspect you're seeing one of the many additives that settled out or isn't mixed well.
Aug 26, 2016 at 3:40 AM
AMBER16
Its got spots like mold in it and is stringy in the liquid
Aug 26, 2016 at 3:44 AM
CARADIODOC
  • 34,414 POSTS
I think you're seeing additives that will mix in the engine. Those are things like water pump lubricant, corrosion inhibitors, and anti-foaming agents. Mold DOES grow in ethanol, which is alcohol. Antifreeze is alcohol too, but mold needs air to grow. If your antifreeze was in a sealed container, I doubt it's mold. Regardless, it's not going to hurt the cooling system.
Aug 26, 2016 at 3:52 AM
AMBER16
Ahh ok thanks so much for your help :)
Aug 26, 2016 at 4:06 AM
WRENCHTECH
  • 20,760 POSTS
Maybe a little bit of oil floating from contamination?
Aug 26, 2016 at 6:01 AM
