Small amount of coolant was put into the brake fluid
80,000 MILES
SKENNYSEA
I put a small amount of coolant in the brake fluid about a half a cup. will it effect the brakes?
Jul 30, 2019 at 7:32 PM
  • 110,248 POSTS
Welcome to 2CarPros.
Yes, that is a problem. If you used the vehicle since you did this, the system should be flushed and inspected by a trained individual. If it wasn't used and the brakes never applied after the mistake, remove everything from the master cylinder, wipe everything clean, and refill with brake fluid. I would still have it looked at for safety.
https://www.2carpros.com/articles/how-to-bleed-or-flush-a-car-brake-system
Jul 30, 2019 at 11:34 PM
