Coolant/water leak
2005 BMW X3
130,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
TINA MADDEN
Light goes on to add water/coolant. I add and within minutes of driving back on again. Usually fill three or four times and then I am good for weeks. Tonight I filled and was all good. Drove to grocery store and back about a mile round trip water coming out of bottom of car.
Nov 15, 2017 at 12:29 PM
  • 110,241 POSTS
What needs to be done is an inspection to locate where it is coming from. If you can safely lift the vehicle and remove the under car covers, do so and see if you can tell approximately where it is coming from (front/rear/side).
Nov 15, 2017 at 12:49 PM
