Coolant Temperature Sensor location and replacement instructions needed
94,000 MILES • 3.6L • V6 • 2WD • AUTOMATIC
TYLER6195
I need to replace my coolant temperature sensor and I can't seem to find it. Could you tell me where it's located and also some tips when replacing it?
Jan 5, 2022 at 8:57 AM
  • 110,248 POSTS
You will need to drain some coolant from the system. Never do this when the engine is hot. Allow the engine to cool before working on the cooling system
The ECT is located on the rear of the driver's side engine cylinder head. If you look at the two pics below, they provide the directions for removal and replacement specific to your vehicle. Additionally, there is a picture of the sensor location.
When you do it, make sure the engine coolant in the radiator is drained below the level of the sensor because the coolant will leak out, unless you are really fast. LOL
Also, here is a link you may find helpful. It explains in general how one is replaced. You may find this guide more beneficial than the one below.
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
If you look at the last pic below, it shows where the drain on the radiator is located. It will be at the bottom right side of the radiator. (Passenger side)
I hope this helps. Let me know if you have questions and how things turn out for you.
Jan 5, 2022 at 10:49 AM
