Where is the coolant temperature sensor located?
115,000 MILES • 3.0L • V6 • AUTOMATIC
NICK SMITH4
I have searched for hours trying to find the answer as to where the location is of the coolant temp sensor. I have seen videos but none for the car listed above. I can’t seem to find any good or accurate answer as to where it’s located.
May 7, 2025 at 7:07 AM
LUCASNIC
  • 13 POSTS
Hello! Here are a couple of screenshots to help. This engine uses a Cylinder Head Temperature sensor instead of an Engine Coolant Temperature sensor. The PCM uses CHT to determine engine temperature instead of the ECT for this vehicle. It is near the thermostat. The picture of the exploded view of the thermostat shows where that is. That is the flex plate so it would be on transmission side of the engine. The second picture shows the location of the CHT sensor, you can see the thermostat in the picture to the left of the sensor. Hope that helps.
May 7, 2025 at 4:24 PM
LUCASNIC
  • 13 POSTS
Got the screenshots to upload, thank you and sorry for any confusion.
May 7, 2025 at 4:26 PM
NICK SMITH4
I am still having a hard time locating it. Can you direct me from this picture as to where I should be looking?
May 8, 2025 at 1:25 AM
  • 55,694 POSTS
Great answer LUCASNIC! You might need to move the hoses and wiring harness to see it. It should be just to the right of the thermostat housing.
May 10, 2025 at 4:24 AM
