How many coolant temperature sensors and where are they located?
225,000 MILES • 2.2L • 4 CYL • 2WD • AUTOMATIC
ACEMANTWO06
  • 9 POSTS
I need to know how many temperature sensors there are and where they are located. Also the temperature sending units for the radiator fans.
Thanks, Al
Aug 31, 2021 at 6:03 AM
  • 110,251 POSTS
There are three on the vehicle. One is for the gauge/fans and the other for the powertrain control module.
If you look at pic 1 below, I included the sensor A sensor. It is tied into the cooling fans. Pic 2 shows the other two.
I also attached the wiring schematic for the fan circuit. It was a page long. I had to cut it in half to make it readable for you. I did overlap them so you can follow from one to the next.
Here is a link you may find helpful when testing wiring:
Aug 31, 2021 at 2:25 PM
ACEMANTWO06
  • 9 POSTS
Hmmm... I will look at it in a day or two. I will also send some pictures of what I am looking at. The information is useful. Also I circled (1) It had a long brass rod. For (2) does it have a flat bottom to it?
Sep 3, 2021 at 1:18 AM
  • 110,251 POSTS
Hi:,
If I recall, yes. If you are having a problem with overheating or the fans not turning on, pic 1 above is the one I suspect is the one to focus on.
Let me know,
Sep 3, 2021 at 2:18 PM
