Where is the coolant temperature sensor located?
250,000 MILES • 2.3L • 4 CYL • 2WD • AUTOMATIC
AHICKSJONES
Need location of coolant temperature sensor.
Jan 29, 2023 at 8:32 PM
  • 55,711 POSTS
Sure, the engine coolant temperature sensor is in the middle of the cylinder hear under the rubber plug, check out the images below to show you the location and how to change it out for a new sensor. Please let us know if you need anything else.
Jan 30, 2023 at 2:24 AM
