Coolant temperature
980,000 MILES • 1.6L • 2WD • MANUAL
ATENDER
My coolant temperature will read middle of the temperature gauge at cold start. It's like it's stuck in the middle then when it heats up to operate temperature. The needle sits 1/4 of the way to the overheating section. It won't overheat. its also hard to start car when cold.
Feb 1, 2019 at 9:47 AM
ATENDER
It is 98,000 miles not 980,000.
Feb 1, 2019 at 9:49 AM
  • 110,246 POSTS
First, this vehicle isn't offered in the US, so my manuals don't include it. Therefore, I will not have any technical information. However, these all work very similarly. The first thing you need to check is the coolant temperature sensor. Chances are it is faulty. Check the plug that connects to it for corrosion and make sure it is properly connected. If it is in good condition, replace the sensor. Chances are it has failed.
Here are a couple links that may be helpful:
https://www.2carpros.com/articles/how-a-coolant-temperature-sensor-works
https://www.2carpros.com/articles/coolant-temperature-sensor-cts-replacement
Let me know if this helps.
Feb 1, 2019 at 12:13 PM
