Hi, I have had a Coolant temperature hot light that has come on a couple times in the last week. The light comes on, car dings until turned off. Each time, after turning the car off and turning it back on, it did not come back on. There were four days between the first time it happened and the second. I scanned the computer and had a few codes, but none seemed to be correlated with the temperature that i am aware of. Both fans appear to be running. Thermostat was replaced a couple years ago. These are the codes I received:
P0463 - Fuel Level Sensor A
Circuit High Input
P1189 - Engine Oil Pressure
(EOP) Switch
Circuit
P1811
Maximum Adapt And Long Shift
U1064
Loss of Communication with Body control module.
Thanks for the help!
Circuit High Input
(EOP) Switch
Circuit
P1811
U1064
May 10, 2016 at 10:17 AM
