Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Ford
F-150
Climate Control
Heater
Not Working
Heater did not work this morning
2013 FORD F-150
90,000 MILES • 5.0L • V8 • 2WD • AUTOMATIC
SMITHAE
MEMBER
1 POST
Heater didn’t work this morning. Makes a gurgling noise when A/C is on. Found that coolant was low but can’t find the leak. Any suggestions?
Dec 26, 2018 at 5:56 AM
MASTER ASE TECH
Experienced Mechanic
Hi, I'm Dan. The easiest way to check for leaks is to use a pressure tester. I've attached a link to the procedure to do this.
https://www.2carpros.com/articles/radiator-pressure-test
Oct 19, 2021 at 5:17 AM
Good afternoon,
Besides making sure the coolant level is correct, I would also make sure there is heat when the level is full.
https://www.2carpros.com/articles/car-heater-not-working
If it is, then you need to find the leak and then repair it.
https://www.2carpros.com/articles/car-is-leaking-coolant
If it does not, then you need to check the thermostat and the blend door motor for proper operation.
Images (Click to enlarge)
Oct 19, 2021 at 6:13 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
