Coolant sensor located on the hybrid?
160,000 MILES • 2.5L • 4 CYL • 2WD • AUTOMATIC
AFTERGLOWMN
Where is the coolant sensor located on the hybrid
Mar 19, 2026 at 12:15 PM
STEVE W.
  • 15,405 POSTS
It is tucked into the thermostat housing on the back side of the engine. Look where the coolant lines connect to the housing, the sensor is between them. If you are replacing it, drain the coolant down, then remove the sensor, apply sealer to the replacement and tighten to 15 lb ft, it is tapered so be careful as the housings crack very easily.
Mar 19, 2026 at 11:48 PM
AFTERGLOWMN
awesome thanks so much, this helps a lot. i know right where it is now in the back. thank you!
Mar 19, 2026 at 11:51 PM
STEVE W.
  • 15,405 POSTS
You are welcome,
Mar 20, 2026 at 6:59 AM
