Coolant reservoir is dry
170,000 MILES • 4.0L • 6 CYL • 2WD • AUTOMATIC
MURPH1974
And has a gunk or sludge in the bottom. Should I fill with new coolant into the reservoir as indicated by the owners manual?
May 17, 2019 at 6:51 AM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
It would be a good idea to remove the overflow reservoir and clean.Use a good degreaser such as Simple Green or something suitable to clean that gunk out before adding new coolant. I've attached a picture below.Hope this helps and thanks for using 2CarPros.
Danny-
May 17, 2019 at 10:02 AM
