Level never changes could there be a blockage?
210,000 MILES • 3.8L • V6 • 2WD • AUTOMATIC
MICHELLECHUCK
Aug 22, 2024 at 1:55 AM
  • 55,721 POSTS
Can you open the radiator cap when the engine is cold to see if the coolant level is full? This video will show you how:
https://youtu.be/GSE9skKnOgY?si=F4QiGSFuU0hTjega
If the coolant level is full then the system is working as intended, if it is low I would get a new radiator cap because the seal in the cap has failed.
Aug 22, 2024 at 11:19 AM
