Draining coolant reservoir
116,000 MILES • 6 CYL • 2WD • AUTOMATIC
STEVEMEISY
When draining my coolant do I remove the cap from reservoir or radiator or both?
May 14, 2021 at 4:43 AM
  • 110,251 POSTS
You can remove both. It will allow air to enter the system faster and drain things faster as well.
First, here is a link you may find helpful. It explains, in general, the procedure for draining and flushing the system.
https://www.2carpros.com/articles/coolant-flush-and-refill-all-cars
If you look at the attachments below, they include the directions specific to this vehicle for draining, refilling, and bleeding the system.
I hope this helps. Let me know if you have other questions.
May 15, 2021 at 4:13 PM
