COOLANT RECOVERY BOTTLE NOT DRAINING IN TO RADIATOR
1996 OLDSMOBILE CIERA
80,000 MILES • 6 CYL • 2WD • AUTOMATIC
ROUNDY
The coolant doesn't drain back into radiator from the resevoir recovery bottle? I wonder if it is a bad radiator cap?
Jan 13, 2016 at 7:33 PM
WRENCHTECH
  • 20,761 POSTS
You need to pressure test the cooling system for leaks. If the system isn't sealed tight, it cannot build the vacuum necessary to draw the fluid back in.
Jan 14, 2016 at 2:23 AM
RIDGE12
The spring on the radiator cap had a lot of crapola stuck to it. We cleaned up the spring and removed all the crap stuck to it. That resolved the problem.
Jan 15, 2016 at 4:34 AM
