Coolant problems
2008 FORD ESCAPE
95,750 MILES • 3.0L • V6 • 4WD • AUTOMATIC
JLAMPS91
The other day I noticed my coolant tank was empty after my heat stopped,so I filled it up and got home and it was empty again. Put more coolant. Had heat for a little while then mo heat and empty again. Haven't seen a lot of leaking but there's also foam in the coolant tank..
Jan 2, 2022 at 11:00 AM
SQM
  • 6,383 POSTS
If you are losing coolant that fast, it is likely a leak. Do you see any coolant under the vehicle when parked?
If you start the vehicle and let it idle, does it leak then?
https://www.2carpros.com/articles/coolant-leak-symptoms
Foam in coolant typically points to a gasket leak.
Do you see any smoke coming out of the tailpipe?
Usually if there is a head gasket leak you will get white smoke out of the tailpipe.
https://www.2carpros.com/articles/white-smoke-or-steam-coming-from-the-exhaust-pipe
Check your oil, if there is coolant mixed with it, the color usually turns milky white.
Here is a guide on how to test for a blown head gasket.
Please let me know what else you might be experiencing.
Jan 2, 2022 at 1:01 PM
