Coolant leak
200,000 MILES • 2.0L • 4 CYL • TURBO • 2WD • AUTOMATIC
TJWIREZ
I pour in coolant and it flows just as fast as I pour it in straight through to the oil pan. I've replaced head gaskets and I getting frustrated with why it's happening.
Aug 31, 2021 at 4:00 AM
SQM
  • 6,383 POSTS
Could this be leaking from a hose? Can you see where it is coming out of? As you know coolant should not leak from the oil pan.
So it just happened after the head gasket replacement?
https://www.2carpros.com/articles/coolant-leak-symptoms
Let me know little bit more info.
Aug 31, 2021 at 5:14 AM
