How to flush blue devil out of the cooling system
160,000 MILES • 4 CYL • 4WD • MANUAL
JOHNNYHERNANDEZ42
I have the vehicle listed above L model. The previous owner had an overheating problem. I changed everything from the radiator, to the thermostat. I gave up and said I'm taking my heads apart I knew there had to be gasket leak. I got it apart and saw white crystal like stuff in my coolant ports, apparently the previous owner ran blue devil a gasket sealer through the system, I'm wondering and hoping there is a way I can flush that crude out of both the heads and block? Please I need help and have frantically searched the web.
- Johnny
Mar 14, 2020 at 4:44 PM
STEVE W.
  • 15,411 POSTS
The only way I know of to remove sodium silicate is to use very hot water to dissolve it and flush it out. Clearing it out of heads that are off should be easy, just toss them in a large container, fill it with hot water and let it dissolve. Then use something like a parts washer pump to flush the passages with clean water. Doing the block is a bit harder. I would probably do the heads, use a brush to get as much of the stuff out of the passages you can, then put it all together, leave out the thermostat, and fill it with straight water, run it until it gets hot and then drain the water, do that a couple times and maybe add some radiator flush as well. That should remove most of it.
Mar 14, 2020 at 7:44 PM
JOHNNYHERNANDEZ42
Thank you for the response that was fast. I have the heads soaking right now I'll give it a shot and reply with the outcome.
Mar 15, 2020 at 5:07 AM
STEVE W.
  • 15,411 POSTS
Please keep us informed. I would be sure to keep water in the heater core if at all possible. Maybe connect a couple lines, fill them and plug them. That way the crystals won't form and block the flow.
Mar 15, 2020 at 6:26 AM
