2001 Subaru Forester Burning smell from engine
2001 SUBARU FORESTER
16,200 MILES • 4 CYL • AWD • AUTOMATIC
JERFOB
I recently bought a used 2001 Subaru Forester and I've started to get a smell like burning rubber coming from the engine after I've driven it for a while, especially after driving up hill. I thought the engine might be over heating but the temp gauge stays in the middle. Any advice before I take it to the shop?
Dec 17, 2008 at 4:08 PM
BLUELIGHTNIN6
  • 16,542 POSTS
Sounds like oil troubles. First, check your oil level and also examine the oil on the dipstick and note any burnt smell or extreme dark colors. These are indications that it is way past due for an oil change. If it is low and no oil is on the stick at all, start looking for leaks. If no visible leaks found, it is being burnt internally. This usually results in smoke from exhaust.
Dec 17, 2008 at 4:46 PM
JERFOB
Looked at the dip stick and the oil was really dark, will get it changed this weekend. Thanks for the help!
Dec 18, 2008 at 5:57 AM
