engine overheats
71,000 MILES
XJSHEN
  • 251 POSTS
Pressure inside of radiator abnormally higher than usual and coolant flow out from radiator mouth continuously when open the radiator cap. What is cause of the problem? How to remove those air inside cooling system? I tried normal air bleeding from left and right side, but it does not help to remove the air and reduce the inside pressure. I think that may be caused by intake manifold gasket problem.
Thanks for your instruction and comment.
Jun 24, 2017 at 9:42 AM
  • 31,937 POSTS
Can be a number of reasons. it can be a coolant leak into the cylinder and this can be checked with a head check, which is a simple chemical test to see if exhaust gasses are in the cooling system. most work shops can do this simple test quickly. other reasons can be a faulty thermostat a blocked radiator or a faulty water pump. if you get the radiator checked, have it removed and core cleaned, as a back flush will not do the job here. it may have a number of blocked core tubes restricting coolant circulation.
Jun 24, 2017 at 11:23 AM
XJSHEN
  • 251 POSTS
Thanks a lot for your help!
Actually, I worked with conventional air removing method that was not effective to remove the air in the radiator and reduce the pressure in the radiator.
How to remove the air in the radiator? Is normal air removing method effective?
Thanks for your comment and instruction!
Jun 27, 2017 at 6:10 AM
  • 31,937 POSTS
Run with cap off air should make its way to the top, if you can have the front of the car slightly elevated as this can help
Jun 27, 2017 at 12:19 PM
XJSHEN
  • 251 POSTS
Thanks! I did it but does not work!
Jul 3, 2017 at 9:46 AM
  • 55,732 POSTS
Hello and welcome to the site
It sounds like you have a blown head gasket, here is a test to help confirm the problem.
Please run this test and get back to us we are interested to see what it is.
Cheers, Ken
Jul 5, 2017 at 6:50 AM
XJSHEN
  • 251 POSTS
Thanks a lot Ken!
Jul 20, 2017 at 6:51 AM
XJSHEN
  • 251 POSTS
Problem was solved by replacement of coolant sensor and fan relays.
Thanks for many helps every one.
Sep 1, 2017 at 12:59 AM
  • 55,732 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers, Ken
Sep 1, 2017 at 4:44 AM
