Coolant loss
RONCLAUDY
  • 1999 PONTIAC GRAND AM
  • 3.4L
  • 6 CYL
  • 120,000 MILES
I am losing coolant but have no idea where. I did an oil change two days ago and found no coolant in the oil pan. There is no smoke or abnormal odor coming from the tail pipe. Sometimes you can smell coolant from under the hood but I can never see it or any steam. I have checked the floor for damp or wet carpet and nothing. I have also checked the heater hoses and still nothing. Any help would be appreciated.
Monday, July 31st, 2017 AT 3:35 PM
CARADIODOC
  • 33,975 POSTS
How often do you have to add coolant? Twice a day? Every other month? For a real slow loss of coolant, the best approach is to add a small bottle of dark purple dye, then check a day or two later with a black light. The dye will show up as a bright yellow stain that you can follow back to the source. Be sure to check for the dye inside the tail pipe.
Auto parts stores will have the dye for the fluid being tested, and those that rent or borrow tools should have a black light.
Wednesday, July 29th, 2020 AT 10:16 AM
