Loosing quite a bit of coolant with no visible leaks. I did pressure test four times, twice cold and twice hot at 15 lbs. No pressure loss, no visible leaks. Each test was for thirty minutes. Then did four block test using a block tester with liquid chemical. Two with engine cold and idling and two with engine hot and idling. Again all tests were negative. Each time I checked against the exhaust at the tailpipe and it was always positive. The liquid turned yellow. What I did see was fluid coming out of the tailpipe. I changed the oil and saw no indications of fluid in the old oil. Not really sure what to look for but the old oil looked normal. No milky residue on oil filler cap. Any help would be greatly appreciated.
Jan 30, 2019 at 3:52 PM
