Coolant light keeps on coming on even if I put coolant in it
75,000 MILES • 0.5L • V6 • 4WD • AUTOMATIC
LEXON30
My dash board showed me to add coolant and i did I drove to work and now the coolant light came on again. what can I do ?
Oct 17, 2017 at 5:17 PM
  • 31,937 POSTS
Are you low on coolant? if so get the cooling system pressure tested to locate any external leaks. if the coolant level is okay, the the low coolant sensor may be faulty. check these first.
Oct 17, 2017 at 6:02 PM
