Coolant leaking into oil
2002 GMC SAFARI
250,000 MILES • 4.3L • V6 • 2WD • AUTOMATIC
BLAKERS
We were driving back from another town when the engine shut down involuntarily, we took it to a mechanic and he showed me a bottle of milky white substance. according to my wife a little bit of smoke was coming out of the hood immediately after engine shut off.
I'm wondering if it would for sure be a head gasket or maybe something else?
Oct 16, 2020 at 5:35 AM
Normally if you have coolant in the oil then you have a head gasket issue. However, there are other causes depending on if this is engine oil or transmission oil.
The way to confirm a head gasket is they need to perform this test.
Here is a guide that will help with some of the other causes:
https://www.2carpros.com/articles/coolantantifreeze-in-the-engine-oil
I would suggest they prove out that this is a head gasket before proceeding but it is a good bet that this is what it is. Let us know what happens. Thanks
Oct 16, 2020 at 8:39 AM
