Coolant leaking coolant from driver side bottom of radiator
DSKRILL
  • 1998 CHEVROLET MONTE CARLO
  • 3.1L
  • 6 CYL
  • 132,234 MILES
The car runs regular temperature but low coolant light flashes and stays on. Then when I park after driving coolant is dripping from bottom right side of radiator. Why?
Wednesday, May 23rd, 2018 AT 12:07 AM
HARRY P
  • 2,292 POSTS
Well if it is coming from the radiator, then the radiator is probably cracked and needs to be replaced. The best way to test it is with a cooling system pressure tester. Here is a general how-to guide: https://www.2carpros.com/articles/radiator-pressure-test
You can borrow that tester from AutoZone, Advance Auto, Oreilly Auto Parts, or even Pepboys (I think) for free with a deposit. Just fill the system first, then pump it up, and follow the leak.
Let us know what you find and we'll help you more from there.
Wednesday, May 23rd, 2018 AT 4:24 AM
