Coolant leaking
2010 NISSAN X-TRAIL
130,000 MILES • 2.5L • 4 CYL • 4WD • AUTOMATIC
PORTGAS D ACE
  • 28 POSTS
Hello, i have coolant leaking under the gearbox where the engine connected to the gearbox.
Jan 30, 2020 at 7:03 AM
SCGRANTURISMO
  • 4,897 POSTS
This sounds like you could have a bad freeze plug, to be sure, I would recommend a cooling system pressure test to determine where the leak is coming from. Here is a link below explaining how to do one:
https://www.2carpros.com/articles/radiator-pressure-test
Please go through this guide and get back to us with where the leak is.
Thanks,
Alex
2CarPros
Jan 31, 2020 at 3:31 AM
