Hello, i have coolant leaking under the gearbox where the engine connected to the gearbox.
Jan 30, 2020 at 7:03 AM
SCGRANTURISMO
✓Experienced Mechanic
This sounds like you could have a bad freeze plug, to be sure, I would recommend a cooling system pressure test to determine where the leak is coming from. Here is a link below explaining how to do one:
