Coolant leakage
100,000 MILES • 1.4L • 4 CYL • 2WD • MANUAL
SUDHIR NIMBALKAR
My car is having coolant leakage from lower side. While running no leakage but when I park a car the coolant seen on floor. please guide me.
Jan 6, 2021 at 1:14 PM
DANNY L
  • 5,648 POSTS
Hello, I'm Danny.
I would suggest performing a cooling system pressure test. It is basically a pump that pressurizes the system with the engine off and cold to see where leaks are coming from. Auto parts stores have a tool loaner program and can rent you one. Here is a tutorial showing what is involved:
https://www.2carpros.com/articles/radiator-pressure-test
Once you perform this if you can make a video with your cell phone of the leaks and we will help with giving you repair advice and guides. Hope this helps and thanks for using 2CarPros.
Jan 6, 2021 at 1:43 PM
