procedure and pictures.
REMOVAL:
1. Drain coolant system. Refer to: "Engine, Cooling and Exhaust : Cooling System : Service and Repair" See: Cooling System > Service and Repair
2. Remove left side lower column cover.
3. Remove steering column assembly. Refer to: "Steering and Suspension : Steering : Steering Column : Service and Repair" See: Steering Column > Procedures
ABS Module
imageZoom/Print
4. Remove ABS module, bracket and wiring.
Interconnect And Bracket
imageZoom/Print
5. Remove I/P to body harness interconnect and bracket.
Lower Silencer Boot
imageZoom/Print
6. Remove lower silencer boot at base of steering shaft.
7. Pinch off heater lines under the hood.
Heater Core Plate And Tubes
imageZoom/Print
8. Remove heater core cover. Insert a small amount of towels under the heater core tubes. Remove heater core plate and tubes.
Depress Clips
imageZoom/Print
9. Depress heater core retaining clips.
Accelerator Pedal
imageZoom/Print
10. Pull up on accelerator pedal and slide heater core past.
Brake Pedal
imageZoom/Print
11. Depress brake pedal and remove heater core from HVAC housing.
INSTALLATION
For installation, reverse the above procedures. Install screws to retain heater core in housing. Replace heater core tube inlet O-rings. Tighten heater core tube retaining plate to 3 ± 1 NM (27 ± 9 in. lbs.) torque.
Feb 18, 2018 at 12:47 AM
