Coolant leak problem
200,000 MILES • 3.2L • V6 • 4WD • AUTOMATIC
RICKY COURTNEY
I have a coolant leak happening in the front middle of my engine area. I cannot see where the leak is actually coming from, just that it comes and goes. Last night it dropped a little less than a quart and I do not know how to stop it. I do not know if it is the water pump or something else.
Jul 30, 2017 at 11:26 PM
HMAC300
  • 48,601 POSTS
it could be a head gasket. Fill the system then pressure check it with a tester or you can purchase a chemical to add to coolant auto parts rent tester. See link.
Jul 30, 2017 at 11:35 PM
