Coolant leak/ Overheating
190,000 MILES
CHAT78
My car overheated, when I stopped I saw coolant leaking underneath the radiator on the driver side. I let the engine cool and added water and it was dripping from the same spot.
Jun 10, 2017 at 8:15 AM
HARRY P
  • 2,292 POSTS
Sounds like some part of the cooling system cracked when the car overheated. Likely the radiator itself. You'll want to do a cooling system pressure test. See this article: https://www.2carpros.com/articles/radiator-pressure-test. The toolkit needed can be borrowed at your local auto parts shop with a deposit instead of buying it. Let us know.
Jun 10, 2017 at 11:33 AM
